Elli
Invert Pan/Tilt?
Invert Pan/Tilt?
Elli
You're absolutely right. Actually I wonder if this is true for many other fixtures.
To change this use VisWiz (found in Vis directory).
Select VL_2500Spot from drop-down menu. Open the tree in the bottom window until you find one of the Pan values (it does not matter which). Then edit the Low and High Output to be the opposite. So where it says 270 change to -270 and change -270 to 270. This inverts the mapping to the actual dmx values. Then save the file.
To complicate matters I've had problems with the application on console where it won't show me the fields to edit these values. If this happens then the solution is to do this on a PC. Note that VisWiz needs associated .r20 files. Probably the easiest solution is to copy the entire Vis directory to a PC.
Finally, you must start a new theatre for this to work because the vis files are stored within them and cannot be updated once started.
The procedure is awkward as hell but it does work!
The Situation was following: It was a Festival with 2 Console. Avo Pearl Expert and GMA Fullsize. When GMA was working, the Avo was for Preprograming and vice versa. So i hat to Invert the one Lamp for Show, and uninvert for Programing at the Console. It also didn't work on GMA. But in that case this where a good Tool.
LG, Elli
LG, Elli
Users browsing this forum: No registered users and 4 guests
