I am running an Azure Shadow with a newly acquired graphics tablet. I was trying to use the color picker with some Chauvet LED lights but was not getting any changes. Is there something special that needs to be done to utilize this feature with RGB fixtures or does the graphics tablet only work with CYM fixtures?
I also have two Robe Color wash 250's with CMY color mixing and the color picker kind of works. When I move the pen across the color section I get changes in colors of the fixture, but I do not get the same color that the pen is pointing at. Is there a way to fix this?
Thanks.
Brian
RGB lights and the Graphics tablet
I have the same Problem! I wanted to use the Graphic Tablet on a Pearl 2004 for the next show! Because i will have a lot of LED Fixtures wit RGB Color mode! Does anyone have a solution for this?
I checked with a modified Library where i changed the 3 Color chanels to CMY! This was the Coulour Control Field worked! But the printed Color on the inlay is not the same than the resulting Color-Mix!
I hope to find a solution for this Probelm! Because the Graphic Tablet would be a verry nice gadget do pick the Colors.
(Maybe this could be done with a software update?)
I have now the Software Version 1.2
Thanks in advance to anybody how knows how to fix this!
Yves
Yves
