Pearl Expert Titan Personality Problem
frenky
Postby frenky » 28 May 2009, 06:13
I'm having a problem that the personality file is not working for a moving head, because when I push the "Locate"-button, it when move very slowly. and it will not react at all. The probleme here is that the "P/T-Speed" is on (100%), so I change the value in the attribute with the wheels and then it will move normal. But only for that time and not standard for all that type a fixture.
How can I change the value of the speed in the personality file, because you can't replace or added a new personality file that will be recognized or added in the Titan-software???
Frank
Postby niclights » 28 May 2009, 11:35
You can replace and add personalities for Titan, but to edit and create you need extra software.
Please submit a bug report for this fixture through the personality library:
http://www.avolitesdownload.com/Persona ... efault.asp
frenky
Postby frenky » 28 May 2009, 12:34
Oke thanx, and the additional software can I get by sending a email to fixturesupport@avolites.com, right?
Frank
Postby niclights » 28 May 2009, 12:37
No harm in asking.
