Hello staff
I have a doubt here that I think will not be complicated to understand and vcs or meet me, counting on the kindness of todos.A and the following question: I have a scene with all movings in blue and with a Gobo any, and in the middle of the song is a solo guitarist and in focus of the attention that I want to make music with it I will determine that 4 movings of my 18 that is blue is to direct him in red and no end of land I gobo.No to lowering the fade that the red soil in it and want it to just the 4 movings go back to previous scene in blue and gobo.Isso and possibly do so or I would have to do another scene with the scene in blue so that when I finish the soil has enabled for it back as it was? THANK YOU VERY MUCH.
(Sorry for the ME MORE ENGLISH AS SOU DO BRASIL, m counting on the help of a PROGRAM TRANSLATOR)
Little doubt
Thiago Oliveira Martins
You can set the playback to mode 2, which will allow you to return back to blue+gobo when you lower the fader.
For this to work the attributes used must all be set to fading.
First I will show about the fader in mode2:
- Program mode
- [edit times]
- press SWOP key for the red+no gobo 'solo' playback.
- press the [mode] softkey.
- press number 2.
- press <enter> twice.
Now test:
- Set lights to blue+gobo.
- Raise 'solo' fader.
- Lower 'solo' fader.
Lights should change back to blue+gobo.
If colour stays red and/or gobo stays open then this is because one of the attributes is set to 'instant'.
To change to fading:
- Program mode.
- Patch
- [Patch Utilities]
- [Set/reset instant/fade]
- Press attribute button for attributes you need to change.
- Then press either blue or grey preset key for each of the fixtures you need to change. The blue key represents one of the attribute banks (or wheels) and the grey is the other.
You need a VDU screen connected to see how things are set, or you will just have to guess!
Hope that helps.
- Program mode
- [edit times]
- press number 2.
Now test:
- Program mode.
- Patch
- [Patch Utilities]
Hope that helps.
Hello Niclights
Firstly thank you very for your help, so I have very bad news for you to! Unfortunately failed, did the two ways that you said it would actually work and 50%, using the mode 2 because I can take the blue and go and back in red soil in a move much more smoothly, so that when he returns remains to finish the scene scene in blue so that the soil color (red). Most of all thank you so much for the information
