Effects on Pearl...
KIS
Effects on Pearl...
Postby KIS » 12 Aug 2004, 12:03
Hi.
I've tried to make the fader take contol of ex. radius of a circle. didn't manage it.
This can be done in an easy way, I've heard, but how?
Thanx,
K. Ivar Skjorestad
Postby niclights » 13 Aug 2004, 02:27
Create the shape and store on a Playback
In Program Mode:
[Shape Generator]
[Playback Parameters]
Hit Playback Swop button of shape
Hit [Toggle Size] Softbutton until display reads Size is Timed.
This should automatically set Playback to Mode 2.
That's it!
You can also use these 'timed' parameters with an LTP fade time to fade in a shape.
Hope that helps.
Nic
galaxyshow
How?
Postby galaxyshow » 13 Aug 2004, 21:36
Hi, could you tell me how to make a Fader controlling the Shape Speed on AZURE?
Postby niclights » 14 Aug 2004, 15:34
Same as above, except you want to toggle speed until it reads 'timed'.
Remember the fader must be set to mode 2 for this to work.
Nic.
Guest
Postby Guest » 17 Aug 2004, 08:35
[/quote]
Hope that helps.
Nic[/quote]
OK. So that's more or less the same as the "damped" effect on Hog desks? Or is it possible to to that on an Avo?
Regards
Postby niclights » 17 Aug 2004, 20:06
Yes, similar to hog.
This gets rid of the messy 'snap' to the start offset of a shape. The use of 'timed' and LTP fades was never documented.
The only other way to avoid a 'snap' is to set the size to timed and manually fade the shape in and out on mode 2 - though this is a compromise.
I don't recommend setting a LTP fade time and using the fader on mode 2 at the same time!
Best regards,
Nic.
