Urgent driver
Urgent driver
is there are any one can help me where can i find the ZOMAX-575-2 DRIVER FOR AVOLITE or i dont how to create own mh driver on avolite can anyone teach me how to do that guys it really urgent
SARAVANAN ARIOLI
LIGHTING PROGRAMMER
SUPER SOUND & LIGHTS ENTERTAINMENT SERVICES
LIGHTING PROGRAMMER
Please submit your request at the Personality Library
If you need it immediately then you can create it yourself. Details are in the manual with plenty of discussions here in the forum. You should search for 'personalities' or similar.
Alternatively you could try using Raul's Personality Builder
If you have any difficulty then come back and we can try and help.
Tanks & Need Help
Dear Sir,
Thanks for your advice on my post but still i have some problem to create
the personality for zomax 575-2, by using the personaliti builder i have
someprob on the creation side like the channel type (HTP, LTP, Instant)
(16bit LTP not fade, 16bit LTP, Part Of A 16bit ch) all those thing i dont know
which one to select, i have send a request on AVO personality request but
till now no reply. i relly hope you can help me as soon as posibble guys.
SARAVANAN ARIOLI
LIGHTING PROGRAMMER
LIGHTING PROGRAMMER
As a rough guide, you can set Dimmer to HTP and all others to LTP.
16-bit is used for more accurate control and requires two channels. These are then combined within the console. Most commonly they are used for Pan and Tilt.
If your fixture uses 16-bit it will be listed as Pan/Pan Low (fine) and Tilt/Tilt Low (fine). Here you would set Pan & Tilt as 16bit LTP and Pan Low/Tilt Low as "part of a..."
HTP = Highest Takes Precedence.
LTP = Latest Takes Precedence.
I understand English is not your native language but I suggest you Google about HTP and LTP. It is very important that any lighting programmer understands these.
If you're still having difficulty you can post a link to a manual or list the fixture DMX channel assignment here.
- zahoorjury
Help Me PLsssss
Channel Listing.
1. Pan
2. Tilt
3. Shutter
4. Dimmer
5. Color
6. Gobo 1
7. Gobo Shake
8. Gobo 2
9. Gobo Rotate
10. Focus
11. Prism
12. Iris
13. Speed
14. Fine Pan
15. Fine Tilt
16. Reset
Pls help me on this china moving head.....thanks alot for your support n Guide Guys
1. Pan
2. Tilt
3. Shutter
4. Dimmer
5. Color
6. Gobo 1
7. Gobo Shake
8. Gobo 2
9. Gobo Rotate
10. Focus
11. Prism
12. Iris
13. Speed
14. Fine Pan
15. Fine Tilt
16. Reset
SARAVANAN ARIOLI
LIGHTING PROGRAMMER
LIGHTING PROGRAMMER
- zahoorjury
thanks alot
Dear Sir,
Hi there, the moving head is working now. Thanks alot for your support n guide. bye tc
SARAVANAN ARIOLI
LIGHTING PROGRAMMER
LIGHTING PROGRAMMER
Users browsing this forum: No registered users and 78 guests
