I have a problem after the boot my VDU screen disapers. I see the BIOS info and the loading of windows but then the VDU goes blank. So it's not the grafics card. Anyone any idea?
Is there a shortcut keycombo like on al laptop? FN+ f1,2,3,4,5,6,7,8,9,0 to toggle the screen. Because i think the grafic card shuts down the VGA output after boot.
TNX
VDU screen EXPERT gone after boot...
There are some keyboard shortcuts to switch the monitor modes. I think Ctrl+F1 or Ctrl+F2 will switch it back to the VGA output. You also want to check in the BIOS that the VGA mode is set to 3. It could also be that your monitor does not support the settings. If you have one try a different monitor.
Update. The console seems to crash when changing the resolution. I managed to boot with VDU enabled by pressing F8 and choosing "Enable VGA" on boot. The console boots normally with the VDU set to 640x680 @ 8 bit. But when I open config panel and change the resolution (display settings); the monitor goes blank again and keyboard LEDs don't respond to capslock/numlock any longer. The console itself is locked up too.
I'm now reinstalling with the recovery disk, hope that helps.
I suggest contact service immediately:
email nick@avolites.com explaining problem and phone. There are often people there late in the evening.
Cool beans. If you have time it might still be useful to mail service and let them know about problem/solution. Sometimes it's the only way these things get sorted.
If you're looking for monitor I bought one of these: http://www.ebuyer.com/product/159248 Great - done a lot of shows already. Can't really fault it. Really useful to have the widescreen for the HUD.
