can a pearl tiger load a show from a pearl expert????
nospipi
Postby nospipi » 17 Nov 2008, 12:46
hi
i switched consoles and im wondering if the new pearl tiger can load
a show from the pearl expert in some way
i programmed you know and i dont want to program again
David.Hunt
Postby David.Hunt » 18 Nov 2008, 11:19
yes the tiger should load your pearl expert show with no problems
nospipi
Postby nospipi » 18 Nov 2008, 12:37
how?
i saved the pearl expert show in a floppy diskette,
if i copy the files into an empty usb flash,the tiger can load the show?
David.Hunt
Postby David.Hunt » 18 Nov 2008, 13:12
apologies i should of put how.
What you need to do is copy the show files to the root of your USB stick.
Then you need to get hold of a program called copy2008.exe This can be obtained from the avolitesdownload website under the link how to copy a show file to USB stick.
The link will be a .zip file which you will need to extract. Then you need to copy the copy2008.exe program to the same place as the show files are in the root of your USB stick.
Run copy2008.exe and this will put the show files in the right place. Then all you would have to do is plug your usb stick into the back of your tiger and load the show.
If this doesnt work then email me. email address is in my profile.
Users browsing this forum: Bing [Bot] and 235 guests
