On a Pearl 2004, is there a way to...
So if it doesn't restore the dipped output when you lower the mode 3 memory - what's the point? Or do you mean it's meant to and just doesn't work properly? In which case, I can say it again - what's the point!
John Peel
www.iadwm.com
John Peel
www.iadwm.com
From the manual:
It's not wrong, just a different thinking.
· Mode 3 - Crossfade cue. All channels, including intensity channels, will fade to the settings in the new cue. All other cues fade out and all other active playbacks become inactive; if you need to re-fire a playback, take the fader to zero and put it up again.
Users browsing this forum: Baidu [Spider] and 17 guests
