Palette Overlap
Michiel3000
Re: Palette Overlap
Postby Michiel3000 » 19 Apr 2019, 18:06
Thanks for your answer, let's hope for the next release :)
Going to try to make it happen with your macros when I have a little more time. Thank you!
Michiel3000
Re: Palette Overlap
Postby Michiel3000 » 23 Apr 2019, 18:59
So I tried out the macros, but it didn't work for me. Do I have to change some things in the macro myself? (I'm pretty new to the avolites API).
What happens right now is when I have nothing (no groups) selected and change palette with overlap 0% they change from left to right. When I select the fixture group on which I change the palette they change from the middle to the outsides. Changing the direction with the macros doesn't change anything. However when I go into the odd/even/all menu and press the macros, I can see the direction changing, but it doesn't seem to have an effect.
Re: Palette Overlap
Postby Gregory » 23 Apr 2019, 21:35
Setting direction in the All/Odd/Even menu does not effect how palettes (with overlap) are applied in the current software. The macros are just a shortcut to change the setting in that menu.
sideshowbond
Re: Palette Overlap
Postby sideshowbond » 25 Apr 2019, 09:19
so it's the direction feature which has to be finished I guess...
