I have done everything like nic has written, but there is one problem.
The gobo speed works ok under fader but only until i locate fixture. After locate the fader work as switch, i can only turn on and turn off the speed but without speed control.
I use Pearl Touch 3.1 and Robin 600 Spot.
How to make gobo rotation ( Robe colorspot ) fader dependant
That is because you have changed the 'origin' value by locating.
I recommend setting up a palette that presets anything important. In this case you would want something that sets a value within the range you are working. So, if in an example your mode 2 fader is CW 100%, then you must do something to preset CW 0%. The locate value is Index 0% and so not in one of the spin ranges.
