Tiger not start
Postby niclights » 13 Dec 2012, 20:24
While you wait for Olie I was wondering what sort of install you did? Was it just the 6.1 installer or did you do the whole 6.0 recovery?
Nicke Löfgren
Postby Nicke Löfgren » 13 Dec 2012, 20:41
Tiger Touch v6.1 Update
Postby niclights » 13 Dec 2012, 21:08
I recommend running 6.0 recovery followed by update. This will reinstall the operating system and associated files whereas the 6.1 update just does the Avo software. That should almost certainly get it all back to normal.
While this does not answer the question why the problem has occurred and is clearly a longer process, in my experience it always ends up being faster than fiddling around trying to solve an issue manually.
Personally I would probably backup my showfiles and anything else then use the 'full' option in this instance.
Nicke Löfgren
Postby Nicke Löfgren » 13 Dec 2012, 21:56
Have just've downloaded Tiger Touch v6.0 Recovery Creator
Completely according to the manual I try and install
Then I run the update 6.1
Have security copied the show
I guess the problem was when we were without power for mixplace
Postby niclights » 13 Dec 2012, 22:23
So it is working ok now, yes?
Like any computer it is possible to corrupt the file system with sudden power loss. This is why it is recommended to use a UPS wherever possible.
Nicke Löfgren
Postby Nicke Löfgren » 13 Dec 2012, 22:56
SUPER THANKS for your help, you guys also
But it was a little "panic" anyway! :oops: :oops: I got the software, but nothing would happen on stage.
Thought any hardware was broken :cry:
I had forgotten to move DMX signal of PearlDesk :roll: :roll: :roll:
