Pearl Expert w/ Titan 6.1 freeze
Literally a couple of minutes before showtime tonight I had a freeze. Had set a walk-in look a couple of hours earlier, walked into the booth just before showtime and the touchwing had an upside down Blue screen and the console would not respond. Text said something went wrong, couldn't take time to read the whole thing as I needed control quickly. Held in the button to force a shutdown, waited a few seconds and restarted, looked normal for a few seconds but while the wing lit up it stayed blank, the lcd started normally but said please wait, I repeated shutdown and restarted again with the same result. I didn't need the wing tonight so I shutdown again and undid the wing and restarted. This time it came up ok though it couldn't load the show so I loaded a saved version. I'll try reattaching the wing after the show but in the meantime any ideas?
Not good. A BSOD is the most serious sort of problem, almost certainly driver or hardware related. Obviously it would be best to contact service about this as soon as possible.
Does your console have an SSD?
And, if the answer is yes and it's an OCZ, has the firmware been updated?
Similarly, but probably less likely, if you have a SATA DVD has this been disconnected?
Note that whenever a console does not shut down normally it will be necessary to load a saved show.
niclights wrote:...Does your console have an SSD?
Similarly, but probably less likely, if you have a SATA DVD has this been disconnected?.
Yes, the Vertex 2 and it was updated during the upgrade to 6.0, No SATA, this is the newer white expert. Show is still on so haven't had a chance to test again yet
Unfortunately I’d have to agree with niclights. It is almost assuredly hardware, and I suspect the SSD also.
I would consider running 6.0 recovery and then 6.1 when you get a chance.
I would also consider obtaining a spare SSD and install 6.1 on it and have it at the ready. Considering the cost/benefit ratio, I would do this with any desk these days as part of the spares kit.
Or a traditional spinner....
The problem with this sort of thing is there might not be anything specifically wrong with the drive and it is an OCZ firmware/driver issue. I have occasional BSOD with a Vertex 3 drive in my desktop. The firmware update with 6.0 was to resolve any BSOD problems but this is reliant on the manufacturer. My understanding is the 330's have proven themselves the most reliable.
SSD's improve boot times and solve rare issues with spinners in high vibration environments (ie. ridiculous sub-bass). Personally I would consider replacing with a spinner unless I was affected by vibration.
All this said, I strongly recommend speaking to service first.
Ok, been speaking with Phil, he IS my service contact here in the US, general agreement seems to be a hard drive issue. I'm going to go buy an Intel 330 locally tomorrow and install it, he is going to check about getting us another one under warranty that I can have as a backup. He suggested asking you guys if there is some utility I can use in the meantime to see if it is indeed a bad HD, like you would check for bad sectors or something. The only other option would be sending it to them for testing and that just really isn't possible with our schedule, no loaners or even an Avo rental around here from what I can find.
