PE 6.1 Cue list allways record by channel
Ferran
Postby Ferran » 07 Nov 2012, 16:15
Hello The Cue List always record by channel.
Although select Stage or Fixture, always does by channel.
It can be changed in any way?
Gracias.
Ferran
Postby Ferran » 03 Dec 2012, 17:33
Anyone else feels the same. Version 5 recorded by fixture.
Postby icke_siegen » 04 Dec 2012, 08:42
How did you check this? By actual output/functions, or by cue view?
What I found is that e.g. if you create a colour-only cuelist, if it is inactive, it displays 'I' (intensity) as contained attributes, whereas it really holds only colours (as it's correctly displayed as soon as the cuelist is fired). This seems to be just a bug of which information is displayed - I already filed it.
Ferran
Postby Ferran » 04 Dec 2012, 09:15
Icke Hi, thanks for replying.
If you record a cue list by fixture or stage, as recorded in the cue should be the value of all attributes.
This does not occur.
If I have red the first cue, red in the second and red in third, if I modify the first cue to green, all other cues turn green as they are tracked by the first cue.
If you Unfold the cue list, if you throw any cue should turn the dimmer. This happens not only with the first turn.
Sorry for my English.
Always fixture or by recording in stage.
Simon
Site Admin
Postby Simon » 04 Dec 2012, 12:52
There is a bug with the software when unfolding cues. They will only fire the non-tracked values when unfolded. I can assure you that the cue list is recording all of the values including intensity and colour when in fixture or stage mode as you should see when playing back the list.
If you turn tracking off on the cue list, unfold will fire all of the values recorded in the cue list.
Simon
Users browsing this forum: Google [Bot] and 35 guests
