Titan HUD and patch screen
sunlightevent
Postby sunlightevent » 27 Nov 2012, 01:40
Hi everyone
I'm using a titan mobile V6.1 , When on HUD window the first ten (top) static playbacks is shown correctly but the second row displays nothing , even macros, nor playbacks , is there a special thing to do or is it a bug ?
also patch windows take quite a while to open and display information ( 30 sec) is it normal... ?
Postby niclights » 27 Nov 2012, 12:15
HUD is a known issue.
Is patch view delay happening every time?
ricws
Postby ricws » 28 Nov 2012, 17:22
I have had issues with the patch display taking a long time to open on my PE with 6.1 also
Postby niclights » 28 Nov 2012, 18:59
I have seen it also but I have a feeling it is only when indexing (ie. first install or personality library update). This occurs the same when using standard patch/[fixture] route.
If it occurs every time or occasionally but not after installs then there might be an issue that needs investigating.
sunlightevent
Postby sunlightevent » 28 Nov 2012, 19:29
For me it happened each time I load a show ...
Users browsing this forum: Google [Bot] and 79 guests
