In System/[Assign Mastering], I don't have Master fader available. No Grand, Playback, Preset, Flash or Swop... I just have Speed Master option (Rate and BPM)
Could you help me please.
Thank you
Master fader Titan V6
The purpose of the function is to provide masters on consoles that do not have physical equivalents. Since the Expert has physical masters the assign options don't exist. However, if you really want to put them somewhere else then you can do this by assigning them in another console (for example Titan Mobile on simulator), saving the show and loading it into PE.
Re: Master fader Titan V6
I'm using the same console as well.
As I seen there are basically rate grand master, rate master, and BPM master. I assign one of them to a vacant fader on the console, but nothing happen after I press the button or move the fader. How to use it correctly?
I have already explained this in my reply to your other thread here. If you have related questions please post them there. I strongly recommend updating to the latest version supported by your hardware. Version 6.1 is very old now and it is difficult to provide advice. As far as I am aware there were no differences in hardware requirements between v6.0 and v9.1 so you should be able to change to 9.1. Do you have a reason for not updating?
Users browsing this forum: Bing [Bot], Google [Bot] and 17 guests
