Another Sapphire Touch/Titan question
David Boots
I'm probably just overlooking something but on Avo classics if you bring up a submaster fader and then change pages that sub would stay active until you lowered it.. on the Sapphire Touch lowering the fader does nothing and I have to go to the active playbacks window to release the cue.. this is very annoying.. what am I missing here.
David Boots
David Boots
For the Sapphire Touch to handle playbacks in the same way as other Titan, and indeed classic, desks you should set the option to "Held Over". This refers to the playback being held on the fader when the page is changed. You may need to kill your playbacks and re-fire them for the change to take effect.
David Boots
The active playback held over/not held over doesn't seem to do anything.. So far the best workaround I have come up with is to put a generic cue up on one of the top faders and go to that while I change pages.. unfortunately our show changes daily and they don't waste any time going from one song to the next, so quite often they have to start the song in the dark!!... my next option is to rearrange the playbacks every show to put them in order which will actually be pretty easy to do with the ST's "move" function.. it's a handy button
Also as a minor problem, isn't the track ball supposed to light up? Ours doesn't.
Please note that the held over setting is stored as part of the show file so when you load a different show or start a new show the setting will be changed to the one stored in the show file.
The colour change feature of the trackball has not currently been implemented in the software. This may be enabled for certain functions in future versions.
David Boots
