Pearl Expert External Monitor
TimGregory
Postby TimGregory » 15 Oct 2012, 16:10
I don't always use an external monitor with our Expert but came to do this the other day for the first time since installing V6.
The screen has the 'disabled message'.
I have tried connecting and disconnecting the the external display in the display setup but still get the same message on the screen and can't open any workspace windows.
Any ideas what I am doing wrong?
Tim
Postby icke_siegen » 15 Oct 2012, 16:34
Is a touchwing connected or not?
Sounds like it's not - and the external is connected for the first time. open windows system settings, and set display configuration (in 'change resolution') to 'extended'.
TimGregory
Postby TimGregory » 15 Oct 2012, 16:38
Ah that makes sense. The external monitor is displaying what would be on the wing if that was connected.
I will give that a go.
Many thanks,
Tim Gregory
Postby icke_siegen » 15 Oct 2012, 16:46
To reasch windows system settings, open Tools (top left - should work even if the display says 'disabled'), Control Panel -> More...
In windows settings, select 'Display', then 'Adjust resolution'.
Do not forget that Window expects a separate confirmation after applying changes ('hit OK or it will be reset after 10 seconds')
MbeNL
Issues with T6 (Windows 7 and Pearl Expert Titan)
Postby MbeNL » 26 Oct 2012, 18:29
Im user of an Pearl Expert Titan, with the latest software, Titan 6, but, when I've installed Titan 6, with al driver updates etc. I cant use my LG T1510 SF (Touchscreen) we had this one, before there was Titan software and I can use it for the software. Whenever, now there is W7 at the desk, LG haven't got any drivers for W7 yet... There need to be an upgrade or something from Avolites. Because I need my second screen for pixel mapper software, next to my Expert Wing.
Hope someone has an idea or an smart guy can make an driver working in a few minutes... :)
Kind regards,
Michael (the Netherlands)
