Sapphire Touch Patch Question
David Boots
Postby David Boots » 14 Oct 2012, 14:31
I am loving this console so far :D
The only issue I'm having is when I patch Martin Stage Bar 54's I am only getting 1 or 2 of the cells.. They are the long version but I don't see a specific personality for those... I have tried different personalities, all with the same results.
Any suggestions would be appreciated.. Thank You
Postby icke_siegen » 14 Oct 2012, 14:42
Essentially, you should patch the same number and mode as you have single cells; the personality doesn't feature subfixtures. If you want to make use of subfixtures, you could set the unit to Pixel Grouping = 1 (each pixel individually), RGB, and patch it as Generic RGB, Mode 6x RGB, 18 DMX. Unfortunately, the current personalities do not feature RGBAW and subfixtures. Maybe you could file a request.
