I like to find a way to synchronise a pan saw and tilt saw into a perfect circle, but somehow I can't get this to work very well...
Does somebody have any tip on how to do this?
(I know I can do a circle shape, but a pan, tilt and a circle takes to much space on my mobile)
//HJ
Synchronised shapes
The factory circle shape works by setting pan to be 270 degrees out of phase with tilt.
So you can do this manually with a separate pan and tilt shape where they both have identical speed and size and pan has a phase offset of 270. But, assuming they are on separate playbacks you must fire them at exactly the same time to get the perfect circle.
