I would like to connect my midi keyboard to my pearl ( titanv6), but midi trigger don’t work!
What’s wrong?
I connect keyboard midi out to pearl midi in.
In set up of the pearl, I add new (name keyboard), and add trigger.
I move a fader (exemple is fader roller B1, I have just pan tilt and color on my fixtures)
Trigger type is hardware, and I say OK.
The trigger type is midi, Learn is on, midi channel =1
Commande= note is on when I play on keyboard ( I can see the bargraph)
Value is 36 ( I don’t kwow what is it!)
Min level = 0
Max level= 127
And I press ok
I can see in the triggers in keyboard windows :
Type stimulus action
Midi MIDI:80 3C set hardware fader level roller B1
I come back in prog or run mode.
But when I play on my keyboard, nothing happens.
Can you help me?
midi trigger with titan
maybe you could try it with a dimmer cue at first - this avoids running into an LTP 'problem': of course it 'doesn't work' after the cue was fired previously.
In general I do find it more useful to set it to 'Trigger Type: Item' - this way you really extend the desk, and can control cues which aren't even on active pages.
