Tiger touch not registering clicks on external display
Postby icke_siegen » 30 Nov 2011, 21:44
Anyone noticed this before? Sometimes the Tiger Touch doesn't register mouse clicks on the external display.
- fresh install just before, and no external touch screen ever connected (usually I just use a 17" straight TFT)
- you can move the mouse pointer to the external, but clicks do not work - no action at all
- usually I have all the palettes on the internal, and the channel grid (or cue view and such) on the external.
- if you move the window in question to the internal screen (by using AVO+min/max and AVO+size/pos), you can click and perform all operations - but as soon as you move it to the external: no avail.
- only salvation: total reboot. Switching external off/on in system/display settings or even reloading the Titan software doesn't solve the issue.
Has anyone noticed this before?
jeffbunce
Postby jeffbunce » 02 Mar 2012, 05:19
Are you able to click *using the mouse buttons* the buttons displayed on the external screen?
If you are then it sounds like the touch screen drivers aren't installed.
If you can't click on the external screen, then I can't help.
Beware, touch screen drivers may conflict with the built-in touch screen drivers causing difficult to resolve issues with both screens. My lighting buddy hasn't installed the touch screen drivers on our external screen for this very reason. Take precautions if you venture on and good luck :)
Postby icke_siegen » 02 Mar 2012, 11:01
Maybe I wasn't clear enough: no touchscreen was involved except the internal one, this happened with a freshly installed Tiger Touch, a connected straight TFT (non-touch), and a standard USB mouse. Definitely not an issue of installing unwanted drivers.
Happened to me and others again since...
Users browsing this forum: niclights and 48 guests
