Help with LTP/HTP.....
DeeJay_Bamse
Postby DeeJay_Bamse » 01 Mar 2012, 19:33
Hello.. I need some help with HTP/LTP on my Titan Mobile.... I have written alots of R20 files to my old Asure table... But now I bought a Titan Mobile and have a lot of trubbles with some Personality Files I need..
I will make an BAD example:
I have a Antari X310 Fogmachine with 2 channels..
1: FOG
2: FAN
If I make a CUE on a fader that controlls the smoke output and starts the FAN... But now to the problem. When I turn down the fader to 0 I want the fan to get the value 0 when the CUE stopes... HOW do I do this? Both fadable and none fadable?? FAN = LTP.. I know that I can Use MASK but I think thats it a bad way especially if I have 10 CUE with the same problem every time I make a new show...
Postby niclights » 02 Mar 2012, 00:07
At the moment Titan personalities can only have one HTP channel per fixture.
If you want them both to be HTP then I would probably just patch two dimmers.
Alternatively you can set cues to mode 2 which will fade LTP attributes with the fader.
DeeJay_Bamse
Postby DeeJay_Bamse » 02 Mar 2012, 01:10
Where can I change modes? And is it possible to turn of LTP without fading?
Postby icke_siegen » 02 Mar 2012, 09:00
To change a fade mode, use the 'edit times' menu. In root menu, hit 'Edit Times' (softbutton A), then the playback swop, and set the fade mode ackordingly.
