Titan Mobile Startup Error
jeffbunce
Postby jeffbunce » 29 Feb 2012, 11:55
When launching "Titan Mobile", I get a brand new error code after a little bit of programming and backing up the console -- unfortunately this error code starts after launching but before the red avolites portion of the program loads.
Cannot Execute C:\Program Files\avolites\Titan\Wendisrv.exe -d error=2
I searched the forums for a solid 45 minutes with no answers. Any Idea what the cause of my issue is or how to fix it?
Postby Gregory » 01 Mar 2012, 10:08
This is due to adding eDmx as a DMX output on Titan Mobile which is not supported. To resolve this, please delete the file containing the DMX settings which can be found here: "C:\Program Files\Avolites\Titan\User\DmxInterfaces.usr".
jeffbunce
Postby jeffbunce » 01 Mar 2012, 19:07
Thank you so much -- Now I've got something to work from!
jeffbunce
Postby jeffbunce » 02 Mar 2012, 05:10
**an effort to make this forum as useful as possible
The fix that Gregory posted above did work, but I didn't delete the file. Instead, I moved the file out of the directory, launched "Titan Mobile" successfully, and found that my DMX output settings were different. (what a surprise :P)
After this, I moved the original DMXInterfaces.usr back into it's original place (changes took place immediately in the Titan Mobile program). I then made sure that the eDMX output was disabled and restarted the program.
Fixed! Thanks again Greg!
