I need to use High End DL3 on Pearl 2008, but the personality library had some problem. I try to use personality builder to fix, at the moment I can use, but we can't see attributes contents. for example: Effect can't show
(Safe, CMY Sim, CMY Pix.......something)
pleaes help
Help
I have looked at this and there are multiple duplicate wheel faults in master layer and global layer (both LTP and HTP).
Usually r20 exports from personality builder still require editing after so it is possible this is why you have the attribute problems. But, equally, if they didn't exist in the first place then they still won't.
I will make the edits directly to the r20 files in this case which will ensure everything else is preserved. When complete I will send to you.
