Ihave a little question, about old strobes and how to drive them from a Avo Pearl 2000. I have two old Collyns 1500 strobes that can be driven by 0/10V input, however the input is some kind of trigger, so whenever the voltage changes on this line the strobe will trigger *once* and flash *once*. I drive this analog line with DMX through a common demux from a pearl.
So if i take this fixture as a dimmer channel if I flash the channel, the strobe will flash once. If i want to have a stroboscope effect (with many flashes per second) I can program a very very fast chase to do this (on, off, on , off), however it is not really practical for me because i cannot easily controll the speed of the chase.
I also have two strobes, sometimes i'd like to make a burst on one and then on the other (like a burst chase) and programing this with the previous solution is a pain, it is also very difficult to synchronise this wiht tap tempo because my chase has many steps where i would like to have just two (burst one and two).
So here is my question : Is there a magic fixture type that could allow me to program this easily and generate the flashes at a predetermined rate ? or is there any other mean to make my life easier with this old trigerred strobe ?
ps: sorry to be a bit lengthy but i wanted to be as clear as possible.
How to deal with old trigerred strobes on a pearl?
Maybe you could use a normal dimmerchannel, but with a custom usercurve.
The curve determines what level in the desk corresponds to which DMX-level.
You could make the curve so that every next% swaps the DMX-level from 0-100-0-100%
I don't know if that'll help your cause, but you could try it. fading from 0-100% would mean about 128 flashes in that case.
Also the shape-generator is your friend. You could create your own shapefile that accomplishes the bursts you require.
I hope this helps
I hope this helps
Users browsing this forum: Baidu [Spider] and 72 guests
