Mobile + midi
fiestalj
Mobile + midi
Postby fiestalj » 23 Nov 2011, 15:27
Hi there,
I'm using an avolites titan mobile setup with a behringer BCF2000 faderwing. using the midi in port on the mobile.
Works great, only problem i have is when i assign a fader to a button playback (for example the playback window) then the fader will activate the button every odd value. And deactivate every even value.
I get a readout from these values on the behringer bcf2000 display.
Anybody have any idea how to change this so i can fade in the button ?
Postby icke_siegen » 24 Nov 2011, 10:56
Seems like when setting up the trigger you set the trigger function to 'Latch'. Delete the trigger, create a new trigger, and set the trigger function to 'set level'. That should do it.
fiestalj
Postby fiestalj » 24 Nov 2011, 11:11
Will test this afternoon ! Thanks !
fiestalj
Postby fiestalj » 24 Nov 2011, 12:54
just tested the solution. Works. But it seems i can't fade in a touchscreen button using midi.
Anyone got a workaround for this ? I want to create some extra faders for smoke machine/blinders, etc..
Postby icke_siegen » 24 Nov 2011, 22:43
Well, it DOES WORK, I tried it this afternoon.
Make sure you set the trigger type to 'Item', and trigger function to 'Set Level'
Users browsing this forum: Google [Bot] and 53 guests
