Pearl 2004 Offline Editor Problem
matt.ladkinlx
Postby matt.ladkinlx » 12 Mar 2005, 14:36
Hi there,
am new to this forum so apoligies if this has already been answered I have downloaded the Pearl 2004 software from the website, installed it and have gone to run it. After a few minutes of operation a message box displaying "Sort it out!!" appears on the display screen and i am unable to get rid of it without manually shutting the program down from the task manager.
I am running the software on an XP laptop with a 1.5gb Intel Celeron processor with 384mb RAM and 32mb graphics.
Why is this happening.
Thanks alot
Matt Ladkin
LX Designer + Programmer :shock:
Thumper Audio + Lighting
Postby Thumper Audio + Lighting » 12 Mar 2005, 17:56
Had this problem at the begining of the year.
try this thread.
http://forum.avolites.com/phpBB3/viewtopic.php?t=220
it should help.
matt.ladkinlx
Postby matt.ladkinlx » 12 Mar 2005, 21:12
Thanks a lot. ML
matt.ladkinlx
Still have problems
Postby matt.ladkinlx » 20 Mar 2005, 17:18
Followed path to old question but have the following problem:
When i save it as simfix.reg and open the file an error message:
"you can only import binary enteries from the registry file" appears.
What should i do?
ML
Postby niclights » 20 Mar 2005, 23:50
It may be easier to edit the registry directly.
This is quite easy, but you must be VERY careful!
In XP:
Start/Run....
Regedit <return>
In the editor, navigate to the pearl sim entries, just like you would with directories:
HKEY_CURRENT_USER\Software\Avolites\Pearl\PearlSimulator
Double-click on the 'zoomedbuttons' field on the right-hand side.
Enter '0' (zero) as the value.
Close regedit (there is no save etc.)
HTH
Users browsing this forum: Baidu [Spider] and 48 guests
