First I added a couple of CLS Atmospehere fixtures in my Tiger Touch. After grouping all panels, I edit the group lay-out in the pixel mapper.
The first panel with control (type = Segments+Control, 13 DMX) is shown as a bar of cells and the other panels (type = Segments, 12 DMX) as square.
The panel lay-out of the first panel (with the control) is incorrect, so I opened the CLS Amosphere Personality editor to change the cell lay-out. After changing the lay-out, I saved the Atmosphere Personality and updated the fixture personality.
After re-opening the pixel mapper lay-out editor, I see the first Atmosphere panel with the old (bar) and on top the new (square) cel lay-out with new numbering.
I tried to fix this with reloading the personality, regrouping the fixtures, re-opening the pixel mapper lay-out editor.
How to fix this?
Mixed fixture cell lay-out in pixel mapper
- john rogers
- john rogers
yes, bot modes should have the square layout. The mode "Segments, 12 DMX" is having the correct lay-out.
http://www.cls-led.nl/Basis.aspx?Tid=43 ... 6&Smi=7978
The first panel in the string of panels should have the mode with the control and the others without the control.
But the cell-layout of the mode "Segments+Control, 13 DMX" should be configured as square.
I can fix the cell lay-out of the "Segments+Control, 13 DMX" mode within the Tiger Touch (with help of the Personality editor) but afterwards the cell lay-out is showed wrong in the pixel mapper lay-out editor.
- john rogers
- john rogers
Tried to solve the problem, but was not working:
- restart the software
- reload the Personality (Patch --> Update Personality)
- re-group the fixtures in a new group and open the pixel mapper on the new group
But can anyone reproduce this problem? Because I like to change the cell lay-out of a fixture within Tiger Touch...
It is non blocking issue for now. But each time starting a show from scratch when there is a Personality problem is not an option. (just started a new show because the pixel mapper was not working on old shows...)
We have a standard show to serve most of our performances. Most of the shows we are using the same set of fixtures (more than 50 fixtures of more than 20 different types), large collection of palets and playbacks for busking purposes.
If you are re-using the show, than it is vital that you can update the personality in an existing file. Or...are there other solutions?
Yes, of course.
I have investigated the problem further. This is specific to changing cell layout. Following [update personality] the original layout persists with the new layout appearing as a ghost. I will enter this as a bug.
The purpose of [update personality] is to permit changes without affecting programming and for the most part this works as designed. There is also potentially the alternative option of using exchange fixture which, along with specific mapping, could take care of more complex updates where the standard function doesn't give the desired results, particularly with multi-cell changes.
