MIDI
brian
MIDI
Postby brian » 24 Oct 2011, 16:21
does anybody have any info on midi on the tiger touch
Postby niclights » 24 Oct 2011, 16:42
Section 9.5 of the manual details timecode.
Section 10.4 details triggers.
You can download the manual here
brian
Postby brian » 24 Oct 2011, 17:00
what external timecode sources are there available
Postby icke_siegen » 24 Oct 2011, 17:18
It pretty much depends from what you have available. I recently set it up (for testing only) with an 'external' Soundcard (Edirol UA25) and a notebook running Reaper, see http://www.avolitesshop.co.uk/phpBB3/vi ... php?t=1836
Generally, you'd need either a MIDI-Timecode (MTC) capable software, and a soundcard with MIDI out, or maybe there is some ready-made hardware (sequencer or such) available.
brian
Postby brian » 24 Oct 2011, 19:24
can you recommend such software that works with your console
Postby icke_siegen » 24 Oct 2011, 22:24
Hi Brian,
well, what I can confirm is that I got it running, reliably. But since outputting MTC is certainly only one aspect when choosing a software, I am sure you will agree that there is no point in recommending it without knowing all your other needs. If you want someone to recommend a software, you need to specify what you expect the software to do. You may download and try Reaper for free. You might ask some Steinberg guru.... And probably there are MIDI forums where you'll find many more users accustomed to Timecode.
Sorry mate.
