Need Help Timecode on Tiger Touch :(
Postby icke_siegen » 14 Oct 2011, 08:15
a screen-photo is here: http://www.avolites.de/test/icke_siegen/midi.jpg
Forget about the activated FX - this was from randomly testing other settings. Did a new project today, without touching FX. Same settings, same result - runs straight away.
Only thing which puzzles me in your reaper2.jpg: you enabled the MIDI output - but in the preferences, there is another checkbox to enable timecode on that output - then it reads 'enabled+clock'. Maybe this is worth trying.
fsl.vn
Postby fsl.vn » 14 Oct 2011, 08:41
Hi icke_siegen,
Good to see your result
I tried to enable Send Clock/SPP output , but it still didn't work , have a look at this picture:
http://img.photobucket.com/albums/v402/ ... eaper4.jpg
Maybe my soundcard had problem and i need to replace with other one? :wink:
Could you record an video for me pls ? or could you capture step by step when your set up the reaper and on the TT ?
FSL
fsl.vn
Postby fsl.vn » 25 Oct 2011, 17:57
Hi icke_siegen,
I've bought another soundcard today, it's Fast Track Pro soundcard just like my friend used before. And i will try it tomorrow.
I just want to ask some question :
1. Do i need to enabled send clock/SPP in this picture(tell me how did you trigger with your soundcard) :
http://img.photobucket.com/albums/v402/ ... eaper2.jpg
2. In this picture do i need to config framerate , start time , user value 1...4?
http://img.photobucket.com/albums/v402/ ... eaper3.jpg
3. And in the TT , i go to timecode , change it to Midi Timecode
and enable timer . Is that all?
fslvn
Postby icke_siegen » 25 Oct 2011, 21:36
Unfortunatel I'll have no access to the hardware before tomorrow evening (MEST), will try to answer your questions then.
I sent you a PM. Maybe we could figure this out by e-mail, and post the results here later...
fsl.vn
Postby fsl.vn » 26 Oct 2011, 04:19
Hi icke_siegen,
Now it works like a charm . Thank you for everything .
Here is the picture :
http://img.photobucket.com/albums/v402/ ... -00151.jpg
The problem is my alesis io2 soundcard , it can not convert LTC to MTC . I bought the new one : Fast Track Pro and it works
Brs,
fslvn
