Avolites pearl 2008 with OXO multi beam LED FWC par can
paolonutini
Postby paolonutini » 06 Jul 2011, 21:13
i have an avolites pearl 2008 and i want to connect a lot of new RGBW led par can but i don't find the personnality inside the console, the name of the fixture is OXO MULTI BEAM LED FWC 18 leds of 5 Watts each
Can you find a solution ?
Thanks for your help
Postby icke_siegen » 06 Jul 2011, 22:13
has been requested for a .d4 recently - a quick search didn't come up with any manual/DMX chart. If you could provide such documentation, I am sure help would be possible. Additionally, please file an official request at http://www.avolitesdownload.com/PersonalityLibrary
I don't know if the existant OXO persos would be of great help (manufacturer: unknown, fixture: OXO Minibeam and Minibeam FC)
S.
john rogers
Postby john rogers » 08 Jul 2011, 12:52
To be honest, it would be much quicker and easier for if you checked out the Generic RGBW Personality under the Generic Manufacturer, found here: http://www.avolitesdownload.com/PersonalityLibrary/?mainPage=Main.asp&ID=2529
A large amount of the requests we receive for obscure LED fixtures are covered by a combination of Generic files. It's certainly worth having a look through 'Generic' on the personality website to familiarise yourself with what is already supported. Saves on waiting for a request to be processed. OXO files would only end up with 'Unknown' for a manufacturer name for the time being anyway.
paolonutini
Postby paolonutini » 31 Aug 2011, 10:58
thanks for your answer but I make a test with generic fixture inside the personnality files but i have a problem with the dimmer function and the strob function , in fact i have 6 dmx channels for this fixture i use the mode 2 of the fixture,
DMX CHART Mode 2
1CH Red level
2CH Green level
3CH Blue level
4CH White level
5CH Master Dimmer
6CH Strob function
DMX CHART Mode 1
1CH Red level
2CH Green level
3CH Blue level
4CH White level
Otherwise i make a test with different manufacturer but i don't find the good model it's not easy i fact , for the mode 1 i found a model but i want to use all channels for the strob fonction and the master dimmer
Postby niclights » 31 Aug 2011, 11:37
I can make the files but in the meantime you can use a generic option. These have been updated since your original post:
For mode 2 use 6ch RGBW mode 'RGBWDx'. Shutter can be controlled using 'Generic 1' attribute. This will be fully functional. The only thing you might need to consider is the strobe will be under the 'special' group, rather than intensity. This is important for mask based functions such as release and store palette.
For mode 1 use Generic RGBW
john rogers
Postby john rogers » 31 Aug 2011, 11:51
Alternatively you could use the 1 Cell, 6 DMX mode of the Litecraft LED PowerBar 4 as this has a Shutter Channel with an Intensity flag.
paolonutini
Postby paolonutini » 31 Aug 2011, 16:31
Ok thankyou for your answers ,
okay niclights with this option it's ok , john rogers i make a test with this fixture and i come back to you
