Button uses
peter.rodda
Button uses
Postby peter.rodda » 17 Aug 2011, 18:52
I’ve been programming on the Titan mobile for 2 months now, and there are some buttons I still haven’t found a use for:
The “Update” button
The “Options” Button
The Blue Buttons next to the encoder wheels (although I think I was told they have no present use?)
release (is it the same and AVO+Playback)
Edit (is it only for editing pallets?)
And the red buttons:
Flash on/Flash out
Rem Dim
Lo hight
Next
Could someone summarise them for me?
Postby icke_siegen » 17 Aug 2011, 22:22
Essentially you're right: some buttons are not used right now. To explain this: when designing the hardware, you're bound to do it in a way that it's useful for future software versions - and the Avo guys did a quite good job in that, I believe.
Just some hints:
Open+Options opens the Attribute Editor, and 'Options' opens the Attribute select menu
The Blue buttons beneath the encodes... I am not sure, but tend to believe they're meant to open the '@'-Menu like on the D4
Edit - I think right now it's for editing pallettes
Maybe someone else adds some more...
Users browsing this forum: No registered users and 68 guests
