Problem with Fixture Patch
Mekki
Postby Mekki » 09 Jun 2011, 14:18
Hello
I have a Problem with Moving-Head^s Futurelight DJ-Head 250 Spot.
They have only a Shutter, no Dimmer ( Shutter closed - Strobe effect- Shutter open).
After run Chases, the Lamp are still on., Shutter open.
What can i do ?
Thank you for answer.
Postby niclights » 09 Jun 2011, 14:38
Which console?
Mekki
Postby Mekki » 09 Jun 2011, 14:44
Sorry, Console is a Pearl Tiger
Postby niclights » 09 Jun 2011, 15:26
Only solution is to edit fixture personality and change the shutter channel to HTP
For example from the original:
DMX
2    61   L  15   100   1N   O   1   "Shutter"         250     0     0
END
change the L to an H:
DMX
2    61   H  15   100   1N   O   1   "Shutter"         250     0     0
END
Mekki
Postby Mekki » 09 Jun 2011, 16:11
o.k. Thank you.
john rogers
Postby john rogers » 09 Jun 2011, 22:18
Moved to Personality Builder forum.
