Hey all,
Im having trouble connecting to Light Converse via Titan. In the DMX settings I see under art net that it sees LC and it has an IP, so I assigned line 1, 2, 3, 4 etc to LIGHTCONVERS(IP ADDRESS)(ArtNet)
But still cant seem to make the connection.
I enabled "DMX Output" "Continuous ArtNet Data Stream" and "Always broadcast ArtNet" from the module properties. and then selected "Wireless Network Connection" for my network adapter.
Any help is greatly appreciated, not sure where to start.
Titan Mobile to Light Converse
Billyserious
Billyserious
AFAIK ACDI doesn't run on 64bit OS - the Avo-guys will shed some more light on this.
Either you find a way to circumvent this. Or you download and install another LC OEM version: currently, the Jands Vista OEM is available with Artnet-Input (well, the Avo stage is much nicer).
Hopefully this issue will be sorted soon.
Sebastian
Sebastian
EmmaThompson
Have you checked what the LC universe is set to? When you assign it to a DMX line, then it will automatically assign any artnet node starting at universe 0, however light converse starts at universe 1.
If you press the 'i' next to the node, it will show you what universe is currently assigned, you can change it from this menu.
Emma Thompson
Training and Events
Training and Events
EmmaThompson
Billyserious
