Titan Mobile to Light Converse
Billyserious
Postby Billyserious » 13 May 2011, 08:13
Hey all,
Im having trouble connecting to Light Converse via Titan. In the DMX settings I see under art net that it sees LC and it has an IP, so I assigned line 1, 2, 3, 4 etc to LIGHTCONVERS(IP ADDRESS)(ArtNet)
But still cant seem to make the connection.
I enabled "DMX Output" "Continuous ArtNet Data Stream" and "Always broadcast ArtNet" from the module properties. and then selected "Wireless Network Connection" for my network adapter.
Any help is greatly appreciated, not sure where to start.
Billyserious
Postby Billyserious » 13 May 2011, 08:33
Followup: I downloaded the ACDI software but it crashes when I try and run it
"The application was unable to start correctly (0xc0000142). Click OK to close the application"
I am running Windows 7 64bit, but Ive tried to open it in compatibility mode with all the other OS's.
Postby icke_siegen » 13 May 2011, 10:55
AFAIK ACDI doesn't run on 64bit OS - the Avo-guys will shed some more light on this.
Either you find a way to circumvent this. Or you download and install another LC OEM version: currently, the Jands Vista OEM is available with Artnet-Input (well, the Avo stage is much nicer).
Hopefully this issue will be sorted soon.
Sebastian
Postby niclights » 13 May 2011, 11:15
I'm not sure if ACDI is required?
Assuming LC and Titan are on different machines, make sure the IP range is the same for both - ie. if LC is 192.168.1.2 then Titan could be 192.168.1.3. If they are on the same machine then it will be a loopback IP (127.0.0.1)
EmmaThompson
Postby EmmaThompson » 13 May 2011, 13:53
Have you checked what the LC universe is set to? When you assign it to a DMX line, then it will automatically assign any artnet node starting at universe 0, however light converse starts at universe 1.
If you press the 'i' next to the node, it will show you what universe is currently assigned, you can change it from this menu.
Emma Thompson
Training and Events
EmmaThompson
Also ACDI is not required if you have the version of LC that supports artnet.
Emma Thompson
Training and Events
Billyserious
Postby Billyserious » 15 May 2011, 07:31
Of all things it was that LC starts universe 1 really at 0, which makes total sense.
Oh wait.
Anyhow, thanks for the help, everything is running beautifully.
