highlight and dimmers? on tiger touch
MickMurray
Postby MickMurray » 20 Mar 2011, 05:03
Is there a way to step trough fixtures / dimmer channels not in a group using highlight, e.g. type 50 ,enter, hightlight and then pressing next highlights 51 and so on. Is it possible to change what the highlight function does, for example on a hog you can save a palette which becomes the highlight palette?
Postby icke_siegen » 20 Mar 2011, 10:54
Highlight works within SELECT groups, thus isn't limited to PROGRAMMED groups. In your case, you'd do 50 THRO 60 ENTER HIGHLIGHT ... NEXT...
The actual Highlight values are set in the fixture's personality, thus cannot be changed on the fly (hey, another feature for the wish list)
Sebastian
Postby niclights » 20 Mar 2011, 11:34
Highlight/Lowlight can be changed via Shift+Highlight.
There might be an argument for prev/next to step by fixture number if only a single fixture has been selected. Technically I don't know if that is something that can be implemented but operationally I can't see this causing any problems.
