off / clear release dimmer
I tried the new off / clear to fade the programmer today. Is this supposed to work with moving head dimmer channels too? I had a mac 250 programmed. Assigned dimmer output to a playback fader and cleared the programmer. Then I selected the dimmer channel, used the wheels to trim back the output to 0 and pressed off / clear. There seemed to be a wait time (but no fade) and then the dimmer snapped open again. Bug or supposed to work this way?
EmmaThompson
I think the question was about timed release of HTP where the programmer is at a lower level than the playback.
At the moment if a playback has dimmers at 100% and the programmer at zero then the release doesn't fade the playback in to 100. Instead it waits the release time and then snaps to the playback value. I can't say if this is technically a bug or not but I can see it would be useful if it did fade.
EmmaThompson
