Hello.
I can not enter into any DMX End in Function Properties of Gobo2 in a library for Mac2000.
When you enter a value and press enter this gets to 0, for example I can not set Raw DMX.
Gracias.
DMX End Funcion Porpeties
Hi Niclights, I can not explain it, sorry.
What happens is that I can not enter values in End DMX in any function of the attributes Gobo1 Rot and Gobo2 Rot.
When I try to set to 0 and get a * in the window title.
Gobo1 Rot and Gobo2 Rot are set to 16bit.
At first the library worked ok, I solved a problem and gobos.
Wanting to change the direction of the gobos rotate i ran into this problem.
I can redo library again, but has given me work.
Do not paste a picture so you see the example.
Thanks for your help.[/img]
The * just means the file has been edited.
The Gobo Rotate channels are 16-bit. Before you mentioned Gobo2 which is 8-bit. Sorry for the confusion.
If I try to change the DMX values it works fine. I don't understand why you are having problems. Unfortunately I'm not sure how to help further unless you can think of any other details that might be important?
Note that latest version is currently 26/01/2011. You can check this in the History section of the personality file.
Thanks again.
The library is the latest version. I have test with other fixture and is the same. Dont know what else to do.
See if someone reads this post and I can help.
I built some libraries for my fixtures, I set the colors and attributes for families all went well until I've had with this problem.
Thanks ...
Thanks ...
If you can explain what you want to change then maybe I could do it for you instead?
Is it just that you want to swap the DMX ranges for CW and CCW spin? Having looked at the manual I can see that these are indeed the wrong way around. This is something I have missed when I last updated them.
I can do this quickly and mail to you to check if this is useful?
It works fine for me. I have already made the edit. For you it is probably going wrong for a simple reason but is impossible to know without seeing.
If you would like me to mail it to you then please pm me your email address and I will send.
Are there other things that you think are wrong with the personality? If you have time please let me know so I can make sure they are correct in the library.
Thanks, you're very kind. Also start work very soon.
Got me a big help, thank you.
My email is ferran@arcoirislighting.com
