User Curve on a Pearl 2000
Zydeco
Postby Zydeco » 24 Jan 2005, 09:03
I want to change the user curve by myself on the Pearl.
I have a fix.sys file with me and changed the numbers and alphabets only, not 0s.
Then, I patched some dimmers and set the curve to user.
Moreover, I went to service → tests → Read Fix.Sys on System, so I should have done right, shouldn't I?
However, the Pearl does not seem changed, so I do not know what to do anymore.
Therefore, if anyone knows about it, please let me know how to set the user curve.
By the way, I read a manual and it said that I should use a file called UC.DAT. What kind of file is it?
I checked everywhere on the Pearl, but there was no such file I would be able to install.
Postby niclights » 24 Jan 2005, 21:23
I have never done this myself, but AFAIK you have to create a new file called UC.DAT.
Just a simple text file 256 lines long, each line being a number between 0 and 255.
Try that and see if it works.
I have no idea why it is under 'read FIX.SYS'. The explanation in the old manual was poor, but it is not even covered in the 2004 version. There is a reference to it from Patching, but mistakenly this actually refers you to WHEEL curves!
Zydeco
Postby Zydeco » 25 Jan 2005, 04:06
Where can I install the UC.DAT file from?
Olie
Site Admin
Postby Olie » 25 Jan 2005, 11:58
I have added some help to the Pearl 2004 page on this subject.
http://www.avolitesdownload.com/Downloads/Pearl2004.stm
UC.DAT is the old user curve system and has been superceeded by Fix.sys.
Olie
Site Admin
Postby Olie » 26 Jan 2005, 14:32
I forgot to mention that you need to reset the desk after loading the Fix.sys file before the new settings will take effect.
Postby niclights » 26 Jan 2005, 20:37
Nice table! Can you explain the purpose of High byte and Low byte?
PS: I wonder what happens if I have some values for other memory addresses..??? Only kidding!
Olie
Site Admin
Postby Olie » 27 Jan 2005, 09:44
High Byte is used only for a 8Bit channels.
Low Byte and High Byte are both used for 16Bit channels
You must always specify both though.
Most of the time I would expect the High Byte to be the same as the Low Byte.
Postby niclights » 27 Jan 2005, 13:27
Thanks. That makes sense!
Is there any way to use custom curves on 'intelligents'? I assume only by editing personalities and patching dimmers over the top? Some of my movers have rubbish dimmers - everything seems to happen in the first 20%
Perhaps this could be one for the wish-list.....
