Hello all,
I recently bought a D3 console and i'm currently fitting all my fixtures onto it.
The Problem:
We use a lot of Showtec Sunstrips (bar with 10 halogen bulbs wich all are independently dimmable, like 10 separate dimmers). When I patch these as dimmers it uses a lot of faders. I know for the Pearl 2008 there is a 10 dimmerpack personality (witch can run shape's as well). I couldn't find this personality for the D2/D3.
I tried to create a personality on my own but it has the problem that when I alter one channel, all the channels follow. This is what I made up. Can anyone help me correct this?
; Showtec Sunstrip 10 channel mode |
; personality for the Diamond II |
; History :- |
; Revision | Date | By | Description |
; 1.0 | 25-10-10 |J van Bree | Created |
DEVICE=SHTSUNSTRIP ; Device Name (upto 11 chars) must be enclosed in single
DEVICE23= ; 22 chars after '='
; extra information for softkey prompt lines 2&3
; a total of 22 chars, split into 2 lines of 11
; __ Number of lines of DMX info.
; | __ Number of lines of wheel info
HSTART 3 10 1b05 0 0 ff 0 1 10 10
; | | | | | | | |__ Line number for flash button DMX info
; | | | | | | | from DMX definition (1..x)
; | | | | | | |__ Button release value
; | | | | | |__ Button ON value (ff means use swop/add fader)
; | | | | |__ The TILT arc in Degrees
; | | | |__ The Pan arc in degrees
; | | |__ Date in PC format (1b05==5/08/93)
; | |__ Number of DMX slots used
; |__ Patch direction (0 for mirror, 3 for moving head)
TEXTSTART ; Upto 21 lines of 28 characters
Showtec ;
Active Sunstrip ;
10 channels ;
Created by Jan van Bree ;
(C) ALE Light & Sound ;
www.alelight.nl ;
TEXTEND
; For the Attribute Dictionary refer to file 'dict.per'
; DMX information
; No unused lines allowed between keyword 'DSTART' and last DMX definition
DSTART ; DMX Picture
1 1 0 0 0 0 ; Dimmer 1
2 1 0 0 0 0 ; Dimmer 2
3 1 0 0 0 0 ; Dimmer 3
4 1 0 0 0 0 ; Dimmer 4
5 1 0 0 0 0 ; Dimmer 5
6 1 0 0 0 0 ; Dimmer 6
7 1 0 0 0 0 ; Dimmer 7
8 1 0 0 0 0 ; Dimmer 8
9 1 0 0 0 0 ; Dimmer 9
10 1 0 0 0 0 ; Dimmer 10
;| | | | | |__ Spare (always 0 for now)
;| | | | |__ Attribute name (See list above)
;| | | |__ Curve (0 means no curve otherwise curve number)
;| | |__ Flags (7=inverted, 40=instant, 20=16-bit)
;| |__ Channel type (1=HTP, 2=LTP, 0=Dummy(for 16-bit defines)
;|__ DMX offset (1..255, 0 means DIMMER will be patched seperately)
; WHEEL information
WSTART
8 ffff 0 4 0 0 1 0 1 0 1 0 0 0 0 0 ; 1. Dimmer
8 ffff 0 4 0 0 2 0 1 1 2 0 0 0 0 0 ; 2. Dimmer
8 ffff 0 4 0 0 3 0 1 2 3 0 0 0 0 0 ; 3. Dimmer
8 ffff 0 4 0 0 4 0 1 3 4 0 0 0 0 0 ; 4. Dimmer
8 ffff 0 4 0 0 5 0 1 4 5 0 0 0 0 0 ; 5. Dimmer
8 ffff 0 4 0 0 6 0 1 5 6 0 0 0 0 0 ; 6. Dimmer
8 ffff 0 4 0 0 7 0 1 6 7 0 0 0 0 0 ; 7. Dimmer
8 ffff 0 4 0 0 8 0 1 7 8 0 0 0 0 0 ; 8. Dimmer
8 ffff 0 4 0 0 9 0 1 8 9 0 0 0 0 0 ; 9. Dimmer
8 ffff 0 4 0 0 10 0 1 9 10 0 0 0 0 0 ; 10. Dimmer
;A BBB CCCC D EEE F GG H I JJ KK L L L L L ;Name
;| | | | | | | | | | | | | | | |__L. List of Table channels as
;| | | | | | | | | | |___K. line numbers from DMX def.
;| | | | | | | | | | 0 means unused channel
;| | | | | | | | | |__J. DMX line (minus 1) pertainig to this wheel
;| | | | | | | | |__I. Number of chanels under control OR Table width
;| | | | | | | |__H. Table type (Attribute number) 0 means NOT a table
;| | | | | | |__G. Wheel number (1..8 on bank1, 9..16 on bank2 et cetera)
;| | | | | |__F. 0 for 8 bits, 1 for 16 bits
;| | | | |__E. Attribute name from above list (0..MAX)
;| | | |__D. Wheel type (1-offset, 2-Table, 3-Pan/Tilt, 4-Dimmer)
;| | |__C. Default/Locate value (left shifted as necessary)
;| |__B. AND mask, where more than wheel controls same DMX slot
;|__A. Wheel multiplication =16-(bits used)
; eg. for 8 bit channels it is 8, for 12 bit channels it is 4
Diamond 3 HTP Personality problem
janvanbree
- john rogers
janvanbree
