PRLAVOS>DAT
markchouhan
PRLAVOS>DAT
Postby markchouhan » 12 Dec 2010, 09:47
how do i get the file?
My console is not working please help
very urgent
Postby niclights » 12 Dec 2010, 13:14
here or here. I believe the executable contains everything including operating system. Make sure you use the correct one. Installing 2004 OS on 2008/2010/Tiger will mean Usb will stop working and be awkward to fix.
I suggest you call 24hr support on +44 (0)7831 17 8888 to check this is the solution to your problem first.
markchouhan
Postby markchouhan » 17 Dec 2010, 06:28
thanks a lot but, i need the prlavos.dat file and its not available anywhere on there website any idea where i can get it
Postby niclights » 17 Dec 2010, 15:29
Are you sure? It's been a long time since I've used them but I am reasonably confident the executable contains all the files required, including the OS (prlavos.dat).
That is certainly implied here.
