I am trying to locate the Setup DMX outputs screen on the VDU menu's.
The manual (page 130) says: "On the VDU menu, click on Tools, Setup DMX Outputs", but the Setup DMX Outputs option is not there in the Tools dropdown menu.
The VDU menu options in Tools, are the same as the menu options on the desk tools menu...
Where can I find or start the Setup DMX Outputs window?
Kind regards,
Sybren
Tiger Touch: Can't locate Setup DMX outputs
- john rogers
- john rogers
Please forgive my cut-and-pasting directly from the manual:
Hope that helps.
11.4.1 Configuring DMX outputs
Turn the key to System and select [DMX Settings] on the second page of options. The screen shows a list of available DMX nodes (places where you can send the DMX to) on the left, and a list of the 12 available DMX lines (outputs from the console) on the right. Each DMX line can send data to one or more nodes. If you assign more than one node to a line, those nodes receive duplicated data.
You can individually assign Nodes to Lines using the arrow button, or assign all Nodes of the same type using the group assign button. For example, to assign the four XLR output sockets on the back of the console to for DMX lines, you would click on the Group Assign button of the ExpertDMX nodes.
To delete a node from the DMX lines, click on the X button. To delete all nodes from a line, click on the Group delete button
You can show information about the DMX nodes, or the DMX lines, by clicking the i button.
Hope that helps.
