question
question
I work (unfortuneltly) with fixture that has the dimmer and shutter atribute on the same chanell (0-122 dimmer 128-230 shutter 232-255 open) is there anyone that can give me an ideea on how to build a personality file to use these atributes independent...on a pc interface is easy to do this, but I use a Pearl 2004 for my next 4 jobs...thanks
- john rogers
On the Pearl 2004 you aren't going to get independent attribute control. The console is not capable of it.
If you were using Titan I could split the Dimming and Shutter attributes up using two of the wheels. One to select between Dimming and Strobe and the other to control the attribute.
