Has anyone noticed that the display freezes in view/fixture patch ?...The cursor arrows stop working, have to do a warm start to get things going again.
It seems to be randomly intermittent, more likely I just haven't noticed a sequence of repeated button presses.
Regards,
Andy
Pearl 2004 v1 View freeze
Andy,
Yes, I have had this happen to me several times. I find that it happens more often when I am checking my fixture patch and scrolling madly with the arrow key. It freezes up and the only way I have found to unlock the view is to restart the console. I have tried turning the key to service but that doesn't work.
Jim
Jim
Thanks Olie, is this an 'official' bug now?
As far as I can remember, the first time it happened I repeatedly pressed VIEW to try and get the screen to clear, but it didn't work. So that was why I used a re set and from the point on used re set . Should the problem reoccur, I will try the VIEW button again.
Regards,
Andy
Regards,
Andy
I have just discovered how this happens.
Set the LCD View to DMX.
Go into Unfold.
Exit out of Unfold.
Arrow keys no longer work.
This is not actually a bug though. When you enter Unfold the VDU view gets set to chase and so the arrow keys then get assigned to control this view. So when you exit out of Unfold the arrows are still controlling the chase view.
To get the arrows back to the LCD screen simply change the VDU View to "Stage Intensities".
Go into Unfold.
Exit out of Unfold.
