I am having problems with the clear function when I save the personality as a .R20. When pressing clear, the dimmer attribute won't zero out. The fixture deselects, but intensity stays at the current level- outputting that value as well. When I save as a .d4 file, the clear works correctly. Am I missing something in the editor? I've even tried putting a "0" percentage as the clear level on the dimmer.
Thoughts?
Clear function in Classic (R20)
- john rogers
As Nic said, the clear flag used by personality builder is only for .D4 personality files. It 'does exactly what it says on the tin' in that every time Clear is pressed (in Titan or on a D4) the fixture will express any and all Clear values immediately. It is for this reason I tend not to use them at all when I create files for the cache.
In terms of Classic (.R20) personalities, pressing clear will set only HTP channels to DMX zero. In the case of 16 bit Dimmer channels, it is important to ensure that the High Byte is set to HTP as opposed to the Low Byte. (See correct example below):
DMX
1 1 H 18 100 1N H 1 "Dimmer" 255 0 0
0 0 s 19 100 1N H 1 "Dimmer Low" 255 0 0
DMX
