hello,
i'm using a pearl expert 2008.
and i would like to program my chases with the speed on the fader.
so when i put the fader up the speed depents on how high i put the fader.
also i would like the intensite of my moving heads on a master fader may be a playback to
can somewone help me ?
regardz Chris Dekker
speed on fader with chase
chrisdekker
CSmithDesign
a bit off topic maybe:
Using a Titan Mobile: In a cue I can set the shape speed to be controlled by the fader. If I have a chase consisting of two cues each having a different shape, then I can't control the shapes' speed by the fader anymore correct?
I would like to easily manually switch/step between two shapes and at the same time being able to control their speed but also keep the speed at the exact same level when switching shapes.
Re: speed on fader with chase
Hello, I have Pearl 2008 and was also wondering how could I put speed on faders. I see I can't, what is the way to work around this and have intuitive control over speed? Thank you
Unfortunately this is not possible in Classic software. The only speed control that can be assigned to faders in Classic is for shapes. For chases you can control speed after connecting either by wheel or with the tap tempo softkey.
Users browsing this forum: No registered users and 73 guests
