Color Blast profile proble with Virtual dimmer...
muvment
Postby muvment » 28 Apr 2010, 05:06
I loaded an R20 profile for the color blast with the virtual dimmer. However, the dimmer channel does nothing, and its still completely controlled by RGB channels. Do I have to change something to make it work?
Board: Azure 2000
Muvment Lighting
Postby niclights » 18 May 2010, 14:55
The Azure doesn't have virtual dimmer. Perhaps you mean the personality with pending dimmer. This is not the same thing - it allows you to patch a normal dimmer on top. A more typical example might be a VL5 with a tungsten lamp powered from a dimmer which will obviously have a different address to the fixture.
john rogers
Postby john rogers » 19 May 2010, 13:11
Nic's right, though this personality was created in error. Not sure why you'd need a Pending Dimmer on an RGB fixture!
Only the D4 and Titan use Virtual Dimmers. Sorry for the presence of that confusing personality file, it'll be deleted from the library effective tomorrow.
John
muvment
Postby muvment » 28 May 2010, 00:34
so I'm stuck with the same pain-in-the-ass RGB channels of color kinetics with no master dimming channel? I blame color kinetics.
Muvment Lighting
