Pearl Titan V3 question
TimGregory
Postby TimGregory » 08 Apr 2010, 11:52
I have been using the Titan software for a while now and I am impressed with the way it is going. The one major problem I have had is when using it live is when a fixture is selected and in the programmer I then can't connect to a chase to change the speed without clearing the programmer.
I know you can set the grey / blue buttons to tap tempo but try doing that for a slow movement chase!
Is there any chance this is fixed in v3 or could be added to the fix list (if its not there already)?
Thanks,
Tim
Olie
Site Admin
Postby Olie » 08 Apr 2010, 18:02
There is no change to the way this works in V3.0.
One possible work around would be the following. It will however still clear any shapes so it would be best to not run the shapes live from the programmer.
Instead of pressing Clear.
- Hold down Clear
- select [Attribute Options], this should set the clear mask to empty.
- release clear
You fixtures will be de-selected and you will be able to see the connected chase but your programmer will not be cleared.
To make things easier, under [Clear Options] I would set first option to remember mask.
If you do actually want to clear the programmer you will have to set the clear mask again.
[/list]
TimGregory
Postby TimGregory » 09 Apr 2010, 10:27
Thanks Olie,
Will give that a try.
Is this likely to be fixed soon or am I the only person who finds this a problem?
Tim
Postby niclights » 09 Apr 2010, 10:45
You're not the only one, but of course there are so many things that people want.
Since I use quick palette almost exclusively this was something I hadn't had problems with at all, but recently I realised some operators prefer to select fixtures first making this much more significant.
