visualiser dongle?
visualiser dongle?
hi do i need to have a dongle to use the visualiuser with the simulator, and a tiger consol?
									with regards kent nielsen
						ACDI
But you definitely don't need this for a simulator and Avolites Visualiser running on the same machine.
In Vis, create a new theatre and add a single generic dimmer at Univ A, DMX 001. Change to Run mode.
In Simulator Patch one dimmer to a handle on output A, DMX 001.
Raise/Lower the relevant preset handle and you should see results in Vis.
i got it connected. but i cant what i am doing during programing, but when i run the the show i can se the heads moving.
edit. okay, i can se heads moving, but i cant the beam on the heads, it is futurelight phs 575. i have raised handle 1-4 where i pathed my lamps.
the shutter is is set to open, but no beam?
